Asus MW221U not adjusting to 1680 res?
15 Dec 2002
Hi,
I received my Asus this morning, I connected via VGA and tried setting the max resolution 1680*1050. The monitor does not auto adjust to fit onto the screen but does when I adjust to another resolution. I tried manually adjusting but after reaching 100 horizontal there was still an ince of desktop cut off on the left. Any advice please.
Yes:
Put horizontal back to 50. Then set the resolution you want and make sure your desktop background or whatever is on the screen DOES NOT HAVE BLACK EDGES. Then hold down the splendid button for about 5 seconds. The screen will then auto adjust and display correctly.
get yourself a DVI cable mate the difference is worth the cost :)
I tried a VGA cable to see the difference and there was quite a bit as well as the image position problem thingy, trust me you will never look back :)
Ok I am a noob with TFTs, I connected via the supplied DVI cable and got no signal, connected the VGA and found the input selection. TBH I don't notice the difference. Also I don't know what the deal is with ghosting, colour bleed etc - still learning :)
A lot of people said the speakers were rubbish but I have found them to be fine, I use headphones most of the time anyway.
The major advantage of DVI so far as most consumers are concerned is that it means the display doesn't have to guess how to display the signal - it will always know exactly what resolution it's being given and when you run it at native resolution this means it can do an exact 1:1 mapping of the pixels.
This means you don't have to press auto adjust, the image doesn't tend to wander over time as the signal gets out of sync, and you don't have to worry about what your desktop image is :D
Finally, as DVI is a digital signal rather than the analog signal VGA provides, what you see is an exact copy of what was sent. Colours are as 100% accurate as the display can make them and there is no possibility for interferance on the cable to mess with the image quality. This is more important for people who work with images (digital artists, photographers, graphic designers etc) but it's still an advantage.
Whether you personally see much of a difference largely depends on both the quality of the DAC (digital to analog converter) on your graphics card and the ADC (you can guess that one!) in the monitor. These days they can be pretty accurate, but using DVI eliminates the process of converting the signal to analog then back to digital for display so keeps the signal "pure".
Ghosting is what the response time rating of an LCD is all about. There is a small delay involved in changing a pixel on an LCD to the new value for the current image. On your display Asus claim it's 2ms although frankly that's a little optimisic! Because of the delay, a fading after-image (a ghost) can sometimes be seen. This happens especially in high contrast areas as changing a pixel from fully off to fully on (or vice versa) takes the longest time of all.
I'm not sure what you mean by colour bleed - do you mean backlight bleed? That's where the backlight in the display which shines through the LCD panel to provide the display brightness appears to come around the edges of the screen. No LCD can provide a true black, but on some displays the black gets much worse (i.e. lighter) near the edges as light seeps round. Luckily yours doesn't have that problem from reports on these boards so far.
Hope that helps :)
