- 4 Apr 2006
- Norwich
Hiya
got a couple of questions for N55u owners
mine arrived today from OCUK got it all installed and downloaded latest firmware no problems.
unit itself has been on for about an hour at the moment and its really quite hot, had anyone else noticed the unit running hot? is this normal or should I be worried?
also I couldn't find it anywhere in the settings (possibly looking in the wrong place) but is uPnP turned on as standard? and if not where is the setting in to change it?
finally any advise from any other owners? anything I should change in setting or tweak?
thanks in advance all
