** ASUS Networking Products **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Today we have relaunched our range of Asus networking products.
The products we have listed are the height of the Asus product catalogue featuring only proven products. With a range looking to expand drastically in the next few weeks, OcUK is excited to start off with a brilliant set of products that will make your home & business networking lives easier.
With an expansion of the 'Black Diamond' branding due soon, OcUK are set to stock a wide range of the best networking products from a company looking fast set to take over home and business networking with stylish and capable products.
We will be working closely with Asus to provide aggressive pricing and attractive deals on these products on a regular basis.
Asus RT-N56U Black Diamond Dual-Band Wireless-N Gigabit Router @ £88.98 inc VAT
ASUS RT-N56U Black Diamond Combines High Speed Network Performance and Unique Design in Style
The revolutionary new ASUS RT-N56U is the most advanced wireless router available, challenging tradition by dramatically exceeding all expectations. This stylish network enabler combines a series of cutting-edge and powerful technologies to offer you an ideal internet and wireless package, complete with striking design.
Dual-band for Lag-free Entertainment
Double your wireless performance and bandwidth with simultaneous 2.4GHz and 5GHz bands speed up to 300Mbps concurrently. While basic internet applications like browsing or file downloading can occur in 2.4GHz, wireless HD content streaming takes place in the 5GHz band at the same time, so both achieve optimized speeds and you enjoy smooth, buffer-free HD content streaming.
Gigabit Internet Surfing with Hardware NAT
Equipped with a capable hardware NAT acceleration engine and built-in Gigabit Ethernet, it gives you full Gigabit internet performance, making its WAN to LAN throughput up to 2-5 times that of traditional software-based NAT Gigabit routers.
Powerful Online Multitasking at up to 300,000 Data Sessions
Support for a massive data pipeline of up to 300,000 data sessions means the RT-N56U has around 20 times the networking capacity of other high session routers, so multiple data transfer jobs don't slow down even during heavy load.
Plug-n-surf and Hassle-free Management
ASUS EZ UI offers you an intuitive router setup without read manuals. What's more, you can enjoy simultaneous printing and scanning by connecting an All-in-one printer to the router via the USB port. Also connect external hard disks to enjoy instant file sharing with family and friends!
Ai Radar Optimized and Reliable Wireless Coverage
This unique and efficient design drastically increases wireless signal coverage and quality without increasing power consumption. It intelligently adapts beam patterns to local conditions to enable higher-gain directional signal emulation. Ai Radar shapes signals to offer the strongest possible output, transforming what may be a weak omnidirectional signal to a stronger unidirectional one, improving throughput at same time.
Others blast signals everywhere, leading to signal loss. ASUS RT-N56U locks the wireless clients to provide dedicated and stable signals.
- Flexible dual-band lag-free entertainment
- Gigabit internet surfing with hardware NAT(While ISP support)
- Powerful Online Multitasking at up to 300,000 Data Sessions
- Twin USB ports enable multi-role usability
Only £88.98 inc VAT.
ORDER NOW
Asus USB-N10 Micro USB Network Adapter Wireless-N 150Mbps @ £19.99 inc VAT
The ASUS USB-N10 provides superior wireless performance for your PC compared to legacy wireless 802.11g technology. It uses a best-in-class MIFA antenna to deliver consistent HD quality data streaming and a much wider wireless operating range. In addition to providing better bandwidth and coverage, the 802.11n standard it's also backward compatible with 11g and 11b networks, ensuring existing networking hardware can be fully utilized. The wireless USB adapter incorporates an impressive MIFA antenna which is better than PCB and Chip antennas widely used in generic adapters.
Only £19.99 inc VAT.
ORDER NOW
Asus PCE-N10 Network Adapter - PCI Express @ £14.99 inc VAT
• WPS(Wi-Fi Protected Setup) - Quickly set up a secure wireless connection.
• Software AP - Connects your notebook and game consoles to the Internet.
• Supports WEP, WPA-PSK, and WPA2-PSK methods for enhanced security.
WPS (Wi-Fi Protected Setup)
For quickly setting up a secure wireless connection. Press the Hardware WPS button on PCE-N10 about 3 seconds, then press the WPS button on ASUS routers as well. Either you can choose to use software WPS, enabling the WPS utility in the WPS Wizard interface. And finish the setup with 3 steps.
Software AP
Software AP mode allows the WLAN card to act as a virtual access point. The computer needs to be connected to a wired network using an Ethernet connection in order to provide network access to WLAN client.
Only £14.99 inc VAT.
ORDER NOW
Asus PCE-N15 300Mbps 802.11B/G/N Wireless PCI-E Network Adapter @ £27.38 inc VAT
Asus PCE-N15; Wired; PCI; RF Wireless; 300 Mbit/s; IEEE 802.11b;IEEE 802.11g;IEEE 802.11n; OFDM
PCE-N15
300Mbps 802.11b/g/n Wireless PCI-E Adapter
- WPS(Wi-Fi Protected Setup) button - Quickly set up a secure wireless connection;
- Software AP - Connect your notebook and game consoles to the Internet;
- Supports WEP; WPA-PSK; and WPA2-PSK methods for enhanced security.
For quickly setting up a secure wireless connection. Press the Hardware WPS button on PCE-N15 about 3 seconds; then press the WPS button on router as well. Either you can choose to use software WPS; enabling the WPS utility in the WPS Wizard interface. And finish the setup with 3 steps
Software AP
Only £27.38 inc VAT.
ORDER NOW
Asus USB-N53 Wireless-N Network Adapter @ £33.98 inc VAT
The ASUS USB-N53 is a dual-band USB adapter that provides flexible dual-band connection for lag-free streaming and high performance networking. It also has a superior antenna design for extensive wireless coverage. With the bundled USB cable, you can flexibly adjust the antenna to receive the strongest signal. A friendly user interface utility allows you to install and use the application easily, making the USB-N53 a fantastic router both at home and on the road.
Features
• Flexible Dual-band connection for lag-free streaming and high performance networking.
• Power signal transmission for extensive wireless coverage.
• Contains a USB cable that allows you to adjust the adapter for enhanced reception.
Only £33.98 inc VAT.
ORDER NOW
Yay, these must be going to make way for the Asus RT-N56U. Do you know when they're due in?
You mean RT-N66U?
Think I'm going to wait for it. Faster than the RT-N56U but with Tomato! Yes please! It will be ~£140 though! Due between end of Jan to mid Feb I believe.
You mean RT-N66U?
Other EU countries have the N66U already, no idea why the UK doesn't yet. Fairly large thread on the router here http://forums.smallnetbuilder.com/showthread.php?t=6446, seems the initial firmware is pretty messed up, but Asus fixed it fairly quickly.
You mean RT-N66U?
Yeah, I mean the 66. Not worried about the price tag too much. Any decent bit of kit will set you back the same. I just want something that will last, has a good range and performs under load.
I am considering the N66U when it becomes available. However, my superhub seems to be behaving pretty well on the wifi front at the moment so may hold fire.
Mine has actually also been great recently with the wireless, but I have to reset it every few days as it starts to crawl over wired! Strange thing that develops different strange habits with every update!
Agree, the superhub is certainly a beast with many colours. I'm struggling to justify the expenditure of a separate router given the superhub is stable.
My last tweak to allocate a specific channel to use has eliminated then random wi-fi drops.
I've read a lot of good things about the asus and if I needed to buy a router now, it would be at the top of my list.
