Hi All,
I bought a new set of drives for my PC and decided to do a complete new install of everything. My system is a Asus Sabertooth X79, i7 3820 and 32gb of Ram.
All I've done so far is install Windows 7 and all the latest drivers for my hardware.
Last night, after a few drinks, I thought overclocking seemed a good idea. This morning I changed it back to stock to make sure I hadn't loaded any daft settings in my drunken state.
While in the Bios I noticed Asus OC Tuner and set it to run. It overclocked my CPU to 4.675 Ghz and my Ram (which is DDR1600) to 2020 Mhz. The thing is it also took the CPU core voltage to 1.384v. Is this safe?
I have a ton of watercooling in my PC and I've been monitoring the temps for a few hours and they are still really low.
The PC is running better than it even has, and I assume Asus don't add an automatic setting that destroys PC's, but I wanted to check with you guys?
