Asus Offset Voltages
19 Jun 2009
what are the benifits of using offset voltage setting over manual VCORE?
I know they work similar to speed step in that they drop VCORE down when CPU aint under load but can cpu be damaged or have shorter lifespans not running offset voltages
my cpu requires 1.33v and LLC Extream Setting to be stable at 4.6ghz IF i used offset what should i set my offset - and + values???
