Hey guys,
Basically, i tried updating the bios to the november 2007 today, after experiencing issues with my computer, i thought it best i update everything including the bios as well (which i've done countless times)
Having had trouble updating it via the old fashioned Floppy disk (it never found the .Rom on the floppy) i thought i'd try the ASUS Update software.
I installed it, then ran the software, so far, so good. I then located the ROM i had downloaded from ASUS' website and the software proceeded to flash the new bios after checking and deleting the old one in the process...
Unfortunately, it then had an error come up and gave me the option of aborting or trying again, i chose to abort and save any further issues, as it assured me it would revert to its previous unflashed state.
I then thought i'd try flashing again to see if the same error came up (which if it did, i was going to leave it well alone!)
Unfortunately upon reloading the ASUS UPDATE software, it said it couldn't find the ASUS BIOS!! I proceeded to save all my work etc, and restarted my PC to confirm this...
It has not booted since.
I'm guessing the BIOS has been erased/corrupted.
Please, if any of you know of any way to help me restore my BIOS, i'd much appreciate it, im never updating a bios again, i swear!!
