Hi all
Need some help here - I am pretty certain that the P5B-VM board I got yesterday from OC is pooched, but wanna make sure, so I'm looking for suggestions here on what to try next.
Quick story:
New system was purchased a couple months ago - C2D E6300, Asus P5VD2-MX, OCZ DDR2 and a Geforce 7900 GT - all installed and working beautifully. Due to very limited OC options on the VIA based P5VD2-MX I decided to purchase the Asus P5B-VM, which should have more options and better overclockability (IS that a word?)
Anyways, got the P5B-VM, installed it and on powering up the system, no video signal.
Tried the folowing:
Resetting CMOS according to instructions. Still no go.
OC Support wanted me to update BIOS, which is hard to do on a system with no video. Asus has an emergency BIOS restore, but that requires the BIOS to be corrupt or missing and the system to be able to boot up, then it'll look at the attached CD for the BIOS. Tried inserting a CD with the latest BIOS but no go. No read activity on the CD, so that didn't work either.
The reason OC Support wanted me to try the BIOS upgrade was because of previous generations of MB's were not built for C2D CPU's, but the P5B-VM is an intel 965 based board - built with C2D in mind, so I doubt very much that is an issue.
I have removed any peripherals not needed, so it's basically just memory, cpu and power,reset swtiches that are attached to the board.
Is there anything else I can try?
PSU is working fine and is quite capable of handling the loads
500W Enermax ATX2 PSU in use.
Quick story:
Tried the folowing:
