Since the 0604 bios I have had 2 issues that may be related.
Firstly since the update I have been waiting 30 seconds ish after post for OS to start loading.
The loading NVRAM screen would flash up then a blinking cursor would wait FOREVER until it started to do anything.
Now this was ok to live with I just had to be patient.
Now upon trying to correct the error I have cleared the cmos in doing so i dislodged the case intrusion detection jumper. Now even with it replaced, 2 different bioses changed to (can only acces bios after a cmos clear) changing its position, leaving it off clearing the cmos multiple times and going stir crazy I can get past the case intrusion detected.
Is there another Jumper I need to reset it or something? Help!!
