- 28 Oct 2002
I had to POST my new Asus P5E WS Pro (a replacement for a failed Asus P5K WS) with a single dimm to enter the BIOS and manually set the 2.3V DRAM voltage required by my four 1Gb OCZ Flex 9200 RAM.
Having tested, I conclude that changing the voltage from auto allows me to POST with three dimms but not four. I can interchange the third and fourth sticks and it will POST with either but not both.
I shall attempt to manually set the Northbridge voltage at 1.5V to see if that is required for four dimm support.
Anyone got this board or similar and has experience with its RAM requirements?
I shall have to run memtest to check the system assuming I can get it to POST with four sticks by adjusting the NB voltage.
My problem is that I need to test everything before I replace the stock NB/mosfet heatpipe with cooling blocks and add the RAM to the loop. Ideally, I need to be comfortable nothing is fried before I customise the board so I am curious if this board or the x38 chipset has issues POSTing similar RAM at auto?
