Asus P5K E8400 Overclock Help Required.
Wac
Wac
13 Mar 2008
Cheshire, UK.
Hiya all,
I'm looking to give my PC a bit of an overclock this weekend and wondered if I could get some advice on the potential overclock I could get, and also what settings I need to change in the P5K bios to achieve this.
I'll be using the stock intel heatsink that came with the E8400, please see below for my system spec's.
Oh, I must also mention this is my first overclock.
Any advice is very welcome.
Thanks,
Adam. :)
Hmm, if it was a Q6600 i could give you exact settings.
Search google for Clunky's P5K overlcocking guide, it's brilliant, though i got my settings from experiementing and several other sources, but the settings he gives work fine.
(P.S. I though i was the only idiot in the world to pay big money for the P5K premium and a Raptor :D)
Actually, here's the link, an OC guide, and the P5K specific one:
Overclocking Guide
P5K Overclocking Guide
Thanks for the links I'll check them out now! :)
Erm, what did you mean by -
Just curious ... :confused:
Regards,
Adam.
3.6ghz is usually achievable on stock volts and you will see a nice improvement in speed too! all you have to do is increase the fsb bit by bit and test for stability with something like prime 95. i dont know how far people usually go with the stock cooler but i recon 3.6 - 3.8 would be ok
Try these , work fine here, but i can use a 9.5 multi
JumperFree Configuration Settings
AI Overclocking: man
CPU Ratio Control: 9.0
FSB STRAP TO N/B AUTO
- Ratio CMOS Setting:
FSB Frequency: 450
PCI-E Frequency: 101
DRAM Frequency: 900 MHZ
DRAM Command Rate: 2N
DRAM Timing Control: MAN
CAS# Latency: 5
RAS# to CAS# Delay: 5
RAS# Precharge: 5
RAS# ACT TIME: 15
RAS TO RAS DELAY AUTO
REF CYCLE TIME AUTO
RIGHT RECOVERY TIME AUTO
RIGHT TO READ DELAY AUTO
READ TO PRE TIME AUTO
DRAM STATIC READ CONTROL AUTO
TRANSANCTION BOOSTER AUTO
CPU Voltage: 1.312 V
CPU PLL Voltage:1.50 V
FSB Termination Voltage:1.40 V
DRAM Voltage:2.20 V
North Bridge Voltage: 1.55 V
South Bridge Voltage: 1.20 V
CLOCK OVERCHARGING VOLTAGE AUTO
LOAD LINE CALABRATION ENABLED
CPU GTL VOLTAGE REF 0.63X
NB GTL VOLTAGE REF 0.67X
CPU SPREAD SPECTRUM DISABLED
PCI E SPREAD SPECTRUM DISABLED
CONF ADV CPU SETTINGS
CPU RATIO 9.0
C1E SUPPORT DISABLED
MAX CPU ID VALUE LIMIT DISABLED
VANDER POOL TECH DISABLED
CPU TM FUNCTION DISABLED
EXE DISABLED BIT DISABLED
HARDWARE MONITOR
CPU FAN INGORE
Thanks for the info, but am I right in thinking this will overclock to 4GHz? That seems a bit too fast for a stock cooler, I was thinking 400-600 extra Ghz. I may be wrong, as I said I'm new to this.
Thanks,
Adam. :)
Okay, what would you reccommend?
I was told that I could overclock with the stock cool, not by much maybe 400-600 extra GHz.
Thanks,
Adam. :)
i have a artic cooling freezer 7 pro on mine and its fine at 4ghz, i havnt tried it at higher overclocks yet. if you want to spend more go for a tuniq tower or a true 120
edit : just check that whatever you choose fits on your m/b first!
The stock cooler is used on CPUs that run upto 3.6GHz, so it will handle more thermal output, but why buy Intel and just overclock it a little? Something like an Arctic Cooling Freezer 7 Pro won't require you to remove the motherboard to fit it (unclip the fan from the heatsink or you'll have a nightmare fitting it;) and it will be quieter and run cooler.
I think the comment about the idiot bit was self-deprecation and a comment on your good taste. I think. Both items mentioned are first class equipment, and certainly no cause for embarassment.
