Asus P5KC DDR3 recomendations and help
23 Oct 2009
Hi,
Ive got an Asus P5KC motherboard with 2 x 1GB Corsair DDR2 PC6400 memory.
Id like to upgrade to DDR3, which this board supports. (2 x 2GB ideally)
http://uk.asus.com/search.aspx?searchitem=1&searchkey=P5KC
For anyone with experience of this board, which DDR3 memory and bios edition did you successfully use?
Which DDR3 memory would you recommend?
Am I also correct in thinking that I could use the same DDR3 memory with an i5 or i7 compatiable board, should I upgrade to that in the future?
Thanks for all help.
