Last week I assembled my new PC. Overall everything went reasonably straight forward (apart from a few glitches installing the OS) but now I am having a very strange boot problem.
When I press the power button the system starts up for around a second and switches off. I then have to switch the PSU off, remove the cable, reconnect and try to boot again. I sometimes have to do this 2-3 times before I get any further.
When the system finally decides to boot, it still powers up and then powers off after about a second, but then 5-6 seconds later switches itself back on a boots normally. Iv found that all this seems to only happen when I have a USB device connected (wireless mouse dongle and USB speakers) although that may not have anything to do with it.
I have disabled all boot devices bar my HHD, other than that I haven't changed the BIOS at all.
If anyone has any suggestions that would be great, the spec of the PC are as follows:
P5Q-E Mobo (with BIOS 2101)
Intel Quad Core Q9550
Windows 7 RC x64bit
Asus Nvidia TOP GTX 260
500GB Samsung HD
Antec 900 Case
Antec TruePower 650 PSU
OCZ Platinum 4GB 1066MHz RAM
Thanks
Windows 7 RC x64bit
500GB Samsung HD
Antec 900 Case
Thanks
