Hi there, been experiencing a rather strange problem with my ethernet ports on my P5Q-E and Windows 7 Pro 64 Bit.
Everytime i restart my pc, and login to my account, i receive 'No internet connection' over the network icon in the taskbar. This prevents me from doing anything internet related as you would imagine, to rectifty this i have to swap the ethernet cable to the opposite gigabit ethernet port, as soon as its swapped internet access opens and i can surf the net etc.
What iv tried:
1. Installing different drivers, Windows 7 64 Bit, Windows Vista 64 Bit and also windows update gigabit drivers.
2. Bios update, sort of figured this wouldnt make much of a difference and it didnt.
3. Different patch/crossover cables.
4. Two x ethernet cables in each port, then directly connected to the router, wouldnt work until i swapped one of the cables over.
Which to me sort of brings it down to a couple of things, but could do with a second oppinion..?
Firewall, im using Bullguard.
Router setting.
Thanks in advance to anyone who can help.
What iv tried:
Router setting.
