Hi,
I have the following spec pc:
- gtx 480
- Intel Core i7-920
- ASUS P6X58D
- Corsair HX850W psu
If I spend more than about an hour gaming (or running furmark), the pc crashes. The cpu is not overclocked. At the time of a crash, the cpu is running at about 50 degress. The gfx card is around 80 degrees. The mobo is 54 degrees. (According to Aida 64 and coretemp.) These all seem well with spec.
I have tried adding some extra fans although that has not helped.
I have tried swapping out the DIMMS, the gfx card and the sound card and I have tried unplugging all peripherals. I am now considering replacing the mobo as I have run out of ideas.
Anything else I should try?
- gtx 480
- Intel Core i7-920
- ASUS P6X58D
