Asus P6X58D-E Users please help
19 Jul 2010
Belfast, Northern Ireland
I noticed just infront of/attatched to the ps2 ports there is a metal flap. What is this for? it seems like it might obstruct it and it wont sit properly with the I/O shield. Im not sure I will have to check. Another thing I have had a look at the motherboard on the back where the screws go there are mini solder points round the hole, but some are missing/scraped. Do these do anything? I wont be able to use it to see if its working until I buy more parts. Cheers ;)
I take it you mean the metal flaps on the backplate? You bend them up so that they sit on top of the PS2 ports.
The mobo mounting holes with solder are fine. If any don't have any solder on them leave out the standoffs as there is a chance the board could short out.
