Hey,
Just purchased a few bit and pieces and had my first attempt at building my PC, but having some issues on bootup that I'm hoping someone will understand what they mean.
I get 2 slow red flashes on the CPU_LED as well as one on the VGA_LED...because my Antec 300 case doesn't come with a system speaker I'm a little stuck as to what the motherboard is trying to tell me. The boot sequence doesn't seem to start as I get no output on my monitor. I read this thread (http://forums.overclockers.co.uk/showthread.php?t=18118695) and wondered whether I should be keeping that plug in, why is it even there as it says it NEEDS 8 pins to be plugged or will not work.
Assuming my CPU is not screwed would incorrectly placed RAM cause the CPU_LED light to flash?
My Chasis fans are working perfectly as well as my CPU fan by the way.
Can you take a look at my components below and advise that I haven't done something stupid in terms of compatibility please
Intel Core i5 750 2.66Ghz (Lynnfield) (Socket LGA1156) - OEM
Asus P7P55D Pro Intel P55 (Socket 1156) DDR3 Motherboard
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK)
Patriot Sector 5 Viper II 4GB (2x2GB) PC3-12800 1600MHz Dual Channel + 3D Mark Vantage (PVV34G1600LLKB)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ)
Antec 300 Three Hundred Ultimate Gaming Case - Black
Tuniq Tower 120 Extreme Rev. C CPU Cooler (Socket LGA775LGA1156LGA1366AM2AM2+AM3)
Sony Optiarc AD-7241S 24x DVD±RW SATA Lightscribe Optical Drive (Black) - OEM
