Hi all,
I just wanted to make a thread to compile the info on this board so far as people have had some issues. I am getting mine hopefully this weekend so its a kind of reference for myself also, please add any information to this and I will edit;
Issues
Wont POST
Cold Boot
Red LED next to RAM
CPU Fan Error
Possible Corrective Actions
BIOS: BCLK = 100
RAM: 1333MHz;
In BIOS advanced: Ai Tweaker tab > Ai Overclock tuner > Manual
Memory Frequency > 1600mhz
If no result try altering voltage
(stay below 1.6 if possible):
DRAM Voltage (scroll down to see it) > Set the voltage
[Thanks to Gegenki]
RAM: Move to A1 B1 slots
RAM: Press an hold small button on mobo next to ram for it to recognise the new RAM
GPU: place in 2nd PCI-e slot
CPU Fan: Move a fan to the CPU header.
CLRTC -> Remove power cable for 5mins remove mobo battery 5-10mins and then switch the RAM jumper from standard (pin1+2) to Clear (Pin2+3) for 10-15sec and place back. This has helped solve several issues.
Updated BIOS: http://hardforum.com/showthread.php?t=1578865
This is an updated BIOS january 2011 and has helped solve (not in all cases);
Cold boot issues, RAM detection issues and POST issues.
Side Note: Best to not exceed 1.38v CPU on the i5/i6 chips
I will hunt for more issues/possible solutions in a bit. If people have had and overcome any more issues please post
Thanks all and to Matthab who I noticed the BIOS update from
Issues
Wont POST
Cold Boot
Red LED next to RAM
CPU Fan Error
BIOS: BCLK = 100
RAM: 1333MHz;
[Thanks to Gegenki]
I don't understand why it works, but it just does
