Bring up monitor menu --> System Setup --> Light in motion. It has 3 levels which determine brightness then 0 which means off.
Sometimes I notice a slight glitch where even if it is level 3, the light does not come on (after sleep mode for example) so just go into menu again, select another level, then go back to the one you want.
