Asus Prime B-660-PLUS VS MSI MAG B760 TOMAHAWK WIFI DDR4
3 May 2021
Italy
Hello everyone,
I'm considering two motherboards for my next rig:
- Asus Prime B-660-PLUS
- MSI MAG B760 TOMAHAWK WIFI DDR4
I'm going to couple them with an i-7 13700k and 64GB DDR4-3200 along with a fairly standard M2 SSD and GPU (likely 6950XT).
Which motherboard should I get? The price difference between the motherboards is about 30€, nothing radical.
Thank you for any answer!
Don't think the Prime even has flashback, so it might not work with your CPU without buying another. Tomahawk is a much higher spec board. You can't overclock a K CPU without either though, for the record (apart from power).
