Asus PRIME B350-PLUS ok for Ryzen 1600?
18 Oct 2002
West Midlands
This board seems very cheap at the moment.
For my first build since having my Intel ivybridge i5 for since 2012 I am going to pair this with AData 32Gb (2x16gb) of 3000mhz DDR4 and a Ryzen 1600.
I run at stock as all I do is programming (vs2017) with the odd World of warcraft every now and again, and I like low noise more than overclocks.
Should this be ok? I'm slightly worried as this motherboard is the cheapest out there at around £90, but as long as everything is stable I will be happy.
I tested this board with my memory and it worked fine for the money.
Not sure if adata will run 3200mhz like my dimms did but it is a stable board in general and 3.8 should be easy on 1600 cpu.
Thanks. I'm not to fussed about 3200mhz ram, running at stock is fine with me.
One question how much different is the onboard sound Realtek 887 and the 1120 most of the x370 boards have?
