Asus Prime X470-Pro cant find cpu fan
11 Sep 2011
as the title says, pc has been working great until today when i changed the case. everything was removed asif it was a brain transplant so made sure nothing was knocked or bent etc. After building and plugging everything back in on my first boot i got several beeps from the mobo with "cpu fan error" on the boot screen. Booted to bios and it says it cant find the cpu fan but finds my AIO pump and all chassis fans.
Tried re seating it and even trying the cpu fan optional pins but still gives me the same error.
The fans work fine from what i can tell as after running cinibench for a few runs im maxing out at 60°c which is what i was hitting before the case swap.
should i be worried? anything i can check that i may be over looking?
cpu fan speed wire is broken or not in the plug far enough is what it sounds like
Have a look at the plug on the fan :)
i did check the plug out when i switched ports and all seems ok. will take another look later though or see if i can get a replacement wire from thermal take. as everything else seems fine. leds work and so do fans just the mobo doesnt seem to think it exists
