- 19 Jul 2010
- West Oxon
So i've been asked to help a friend identify a second M.2 drive to use on this motherboard (ASUS Prime z390-P) and whilst looking into this, it seems that his second m.2 socket for storage drives is restricted to x2 speeds.
The system has one GPU in the standard x16 slot (unknown type) and one pcie wif card in one of the lower x1 slots (don't know why they didn't use the dedicated E Key'd m.2 slot when the system was built)
So I've posted a question in the storage forum regarding the consequences of connecting a x4 m.2 ssd to a x2 slocket, and will see what the reply from there is.
But it made me wonder, if i did want full speed from the planned additional m.2 drive, could i use an adapter card in the second x16 slot?
so i went and looked in the specs, and found something that I thought i'd ask here for clarity on.......
That is a excerpt from the specifications for the board (linked above)
The Hyper card, i'm not familar with at all, but would guess it's some sort of ssd raid card or similar enterprise derived ssd storage card, which is not going to be relevant, especially as it has to go into the 1st x16 slot, which is occupied by his GPU.
The bit that caught my eye where the 2 lines referring to the x16 slots, and obviously where my interest lies, so the second slot appears to be x4 speed only, not a problem that's exactly what i'd need. BUT, am I reading the 1st slots details correctly?
(x16 or x8+x4+x4) meaning that the 1st slot will run at x16 speed, but will shift down if you put any card in the 2nd x16 slot ?
also that configuration of three values after the initial 'x16 or' speed reference genuinely made me go and look if the board had a 3rd x16 slot!
could someone please explain that (x16 or x8+x4+x4) to me in layman's terms, because right now i "think" it means x16 if slot 2 isn't used, if it is, then it'll be x8 for GPU plus x4 for other card, or if used for crossfire then it'll be x4.
how far off the mark am I? TIA
1 x PCIe 3.0/2.0 x16 (x16 or x8+x4+x4)
1 x PCIe 3.0/2.0 x16 (max at x4 mode)
4 x PCIe 3.0/2.0 x1
1 x M.2 Socket (Key E), supports type 2230 Wi-Fi/BT and Intel® CNVi (Integrated Wi-Fi/BT) module*
*For 3 SSD on CPU support, install a Hyper M.2 X16 card (sold separately) into the PCIeX16_1 slot, enable this card under BIOS settings.
* The Wi-Fi/BT module is purchased separately
