Asus Probe 2 alerts! Hardware fail?
21 Aug 2012
Hi I'm getting really weird alerts from the AI Suite 2 probe for my P8Z77-I deluxe and 3770k.
This follows a suspected failure of an Antec Kuhler 620 and its later replacement with an H100i.
The PC was unplugged over xmas. Problems started shortly after I started using it again.
All cores were suddenly showing over 100 deg C temps (in CoreTemp 1.0, around 80degC in AI Suite, as you can see) with no load, fans were working but the pump block was really hot. I guessed it was the watercooler so removed it and replaced it. Will try to RMA.
[01/25/2014 at 09:48 pm] CPU 76.0 Abnormal
[01/25/2014 at 10:08 pm] CPU 79.0 Abnormal
[01/25/2014 at 10:16 pm] CPU 81.0 Abnormal
[01/25/2014 at 10:36 pm] CPU 76.0 Abnormal
Here is where the Antec 'failed'. The following alerts are after I installed the H100i and started overclocking again.
[01/31/2014 at 06:38 pm] +5V 0.320 Abnormal
[01/31/2014 at 06:39 pm] +5V 5.040 Normal
[01/31/2014 at 08:30 pm] +3.3V 0.064 Abnormal
[01/31/2014 at 08:30 pm] +3.3V 3.328 Normal
[01/31/2014 at 08:48 pm] Vcore 0.152 Abnormal
[01/31/2014 at 08:48 pm] Vcore 1.152 Normal
[01/31/2014 at 09:47 pm] +3.3V 0.000 Abnormal
[01/31/2014 at 09:47 pm] +3.3V 3.312 Normal
[01/31/2014 at 10:21 pm] Chassis fan 911 Normal
[02/01/2014 at 07:42 am] +3.3V 0.064 Abnormal
[02/01/2014 at 07:42 am] +3.3V 3.312 Normal
I found a stable overclock setup (just tested with a heavy vray render and keeping an eye on temps, vcore etc. Details follow).
After this the following alerts showed up.
[02/01/2014 at 01:53 pm] CPU -128.0 Abnormal
[02/01/2014 at 01:53 pm] CPU 28.0 Normal
[02/01/2014 at 02:54 pm] Vcore 1.656 Abnormal
[02/01/2014 at 02:54 pm] Vcore 1.152 Normal
[02/01/2014 at 03:24 pm] +3.3V 0.000 Abnormal
[02/01/2014 at 03:24 pm] +3.3V 3.328 Normal
[02/01/2014 at 04:46 pm] +12V 0.384 Abnormal
[02/01/2014 at 04:46 pm] +12V 12.192 Normal
[02/01/2014 at 06:26 pm] Vcore 0.128 Abnormal
[02/01/2014 at 06:26 pm] Vcore 1.152 Normal
[02/01/2014 at 07:33 pm] +5V 0.000 Abnormal
[02/01/2014 at 07:33 pm] +5V 5.040 Normal
[02/01/2014 at 07:37 pm] +5V 0.000 Abnormal
[02/01/2014 at 07:37 pm] +5V 5.040 Normal
[02/01/2014 at 07:47 pm] +3.3V 0.000 Abnormal
[02/01/2014 at 07:47 pm] +3.3V 3.312 Normal
[02/01/2014 at 07:58 pm] +12V 0.000 Abnormal
[02/01/2014 at 07:58 pm] +12V 12.288 Normal
[02/01/2014 at 09:25 pm] Vcore 0.200 Abnormal
[02/01/2014 at 09:25 pm] Vcore 1.192 Normal
These are my ‘stable’ overclock settings.
4.637Ghz (105.4 x 44)
XMP on
BCLK 105.4 x 44
DRam 1.5v (11-11-11-28)
VCCSA 1.25v
CPUv (VCORE) auto offset
- on load 1.408v - 1.432v
temps +- 80degC on load, +-30 deg C with no load.
I am not getting any crashes since the 'stable' OC, I'd just like to know what is causing these alerts?
Was the probe/hardware damaged when the Antec failed?
Thanks.
