i dont know where to start .....
i purchased an asus r9 fury strix in february from overclockers and have been having no end of issues .... im starting to wonder if the card is bad.
windows 10, constant crashes in 3d games display turns off need to reset system .... farcry primal, hitman, fallout 4 ..... occasionally hearthstone and darkest dungeon can crash too.
tried all versions of drivers curently using 16.3 crimson
no overclocking ... windows power options on high performance
today i tried disabling power efficiency in radeon settings ... card goes crazy fans at max and it locks up windows .... after resetting, my system wont boot unless i completely power the system down and turn off power on psu for 10 sec but then after i boot to windows the power efficiency setting stays off but the card insta crashes with max fans the moment i login to windows.
i have to boot to safe mode and remove drivers with ddu, then install them again .... not touching the settings again !
my temps are all good cpu is in mid 30's under load, gpu during 3d gaming (when it works) is 60c to 70c.
i also have a fan mounted on my case door to cool my ram ect.
my old windows 7 system with a r9 280x never had any issues with crashes
but even when i run fallout 4 on my old windows 7 with the fury i get the same display turns off issue ... but i can at least play for an hour or so but sometimes fo4 crashes within a min or so.
my system .... using outer vision psu calculator my power usage is 555watts
nzxt phantom (orange and black)
sabertooth 990fx r1.0
fx 8350...@4ghz corsair h80 water cooler
16gb ddr3 1866 corsair vengance
asus r9 fury strix
lepa 850watt psu
asus xonar essence stx
asus pb287q 28" 4k monitor
any ideas ? should i consider sending the card back ?
asus r9 fury strix
lepa 850watt psu
