Asus rampage formula o/c help
24 Aug 2003
Gillingham Kent
Has anyone got some values they can give me (especially if you are runnig with the same proc) ie volts and multiplier.
Every time I do the slightest o/c, when you press save the comp shuts down briefly then restarts (I guess this is normal) then goes to a screen saying press F1 to set up bios or F2 to blah blah blah.
Any way an help would be appreciated would like to get beyond 3.6
bios screen shots very welcome
Cheers Gary
When you change the bios it will switch itself off and then restart so thats normal.
Re volts, make sure you ram is at the recomended voltage and that your ram timings are really loose and then start playing around with the multiplier etc. I think you should be able to get 4Ghz on < 1.4 Core voltage. Leave the rest on auto for now.
It does that its crap and it shouldn't mine does the same, disable it in the bios then it will boot up without having to press F1 every cold boot. I have to say apart from that very small niggle its actually a great motherboard and clocks really well.
