== Asus Rampage II Extreme + Intel Core i7 920 D0 4.00GHz Max Bundle! ==
9 Nov 2003
Leeds
I know some of you have been waiting on an Asus alternative to the UD5 Gigabyte bundle and here it is, offering a great cooler with Akasa's amazing Apache fan (excuse the colour scheme as the performance easily makes up for it) this bundle is feature packed and ideal for those looking for the ultimate in performance. :)
Representing the cream of the crop of today's bleeding edge performance hardware, OcUK's 'Extreme Bundles' are selected to satisfy the needs of the most demanding enthusiast. Available with three different levels of overclock your ideal bundle is just one option away.
OcUK Overclocked Bundles feature carefully selected components tested to assure compatability & stability, guaranteeing the integrity of the overclock.
We worry about the fiddling and tweaking, you just enjoy the performance.
This bundle ships pre-built and pre-overclocked direct from our Technical Department. All you need to do is attach the CPU cooler and power it up.
- Maximum Speed
- Maximum Stability
- Maximum Compatibility
- Maximum Overclocking
This Bundle contains the following components:
1 X Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz overclocked up to 4.00GHz! (Choose overclocking option above.)
1 X Asus Rampage II Extreme Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
1 X Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (TR3X6G1600C9)
1 X Prolimatech Megahalems Performance CPU Cooler (Socket 775/1366)
1 X Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM
1 X Arctic Cooling MX-2 Thermal Compound
£619.99 inc VAT
BUY NOW
Oh my God how ridiculously awesome!
Will order 7 of these right away; one for each of my pet dwarves
hoo-ha!
Might be because you want things before we have had time to properly test them. :D
Do you have exactly the same setup?
Ahh good choice, the reasoning behind the Corsair XMS memory and not Dominator/Patriot is due to the feedback we have had on the UD5 bundle, some people have had trouble fitting custom fans and the cooler in certain cases with the taller memory. The Patriot is a bit of an office favourite for the clocking systems.
That combination you have there should be good for 3.60GHz-3.80GHz+ without too much trouble, if you are unsure about how to get going we have an excellent overclocking and cooling section. ;)
Yeah, when I got everything unpacked and started building for a moment or 2 I though I was going to have an issue with the CPU cooler and the RAM slots but it was all good in the end:D
As for overclocking it, yeah, I need to have a good read and start tinkering!
Once my wallet has recovered I'll be going down the water route.
Cheers
That looks a really good deal. My opinion is that if you are going to go with i7 is that you go for the high end hardware otherwise your not using it to it's full potential and getting value for money.
This looks great. And the way i7 should be done :D
