Asus rampage V cpu problem
29 Feb 2012
London
Hi I've just put my water cooling build together when I booted the system the cpu over heat error message comes up and in the bios and reads 93c is there any sort of rampage V glitch?
Or is it best to take the block off and have a look at the contact and thermal paste?
Thanks
I've had no glitch, are you using an EK block?? Have you used the correct posts?? As one set is for use with the backplate, failing that take the block off and blow through the ports to make sure there is no restriction. Is the pump running?? It happens!!
Thanks m8 no it's not I can't undo the inlet fitting might have to drain the gpu loop too and strip it out fully :( defeated today as been working at it for 7hrs all finished.
Come back tomorrow and hopefully get to the bottom of this! So close :(
Frustrating - but kudos on the build, it looks lovely, puts mine to shame. Lol.
Mark
