Asus Realbench
26 Jun 2013
Hello,
Im trying to run Asus realbench but I get the following error about half way through tests "opencl.dll is missing"
System is
Windows 10 64Bit
Asus Hero VIII
6700K CPU
16Gb 3200 Ram
Nvidia 1080GTX
Any suggestions please?
A quick google search seems to suggest its Graphics card driver related.
You running Nvidia?
I would suggest remove the drivers using the product from this link if so:
https://forums.geforce.com/default/...or-new-cpu-core-analyzer-updated-12-21-2015-/
That link is from the official Nvidia forums, I have used it myself, works great.
The obviously reinstall the most modern ones you can.
Similar issues can happen on AMD systems apparently, but it can be a bit more complicated to fix.
