- 29 Nov 2008
- Scotland
Hi All,
I have started having issues with my RIVE,
For a couple of years its been running stable [email protected], 16Gig Team Extreme@2133 and 2x Titans all under water and powered by a Corsair AX1200.
Over the last weekend it has shutdown for no reason and has been stuck in a loop of restarting, no LED boot code.
Powering down and trying again is the same, clearing the cmos is the same also.
Eventually after lots of tries it will boot up and run ok.
Sometimes removing the 24 pin power from the motherboard helps it boot.
Things I've tried so far running with 1 slot of memory, removing all but keyboard and monitor.
I've flashed the 4804 bios before I went away at the start of the week and its been running since then even though it is at stock just now. I only flashed Bios 1.
Anyone else had this weird situation before as I read in another forum it's a failed or failing motherboard.
Kevin
Kevin
