- 7 Mar 2025
- West Sussex
I just thought I would put it out there because there seems to be a lot of people with this problem. Basically after restarting Windows 11 my pc would just hang and would not restart.
All I could do to get around this would be to hold the power switch down to turn it off and then start again by pressing the power button.
When this happened I got a code 0d on the motherboard which according to Asus is reserved for future AMI SEC error codes. After Googling the problem there seemed to be a lot of info
and people saying it is a memory problem. Anyway after hours of testing my memory and thinking I had a serious problem with my pc I came across a thread on reddit which I pasted below.
The setting on my motherboard was set to auto so I changed that to enabled and my problem is no more.
polymeros77
•4mo ago
I seem to have found a solution to the problem.
In the BIOS, under "Tweaker's Paradise" there is an option "Monitoring Software reboot Workaround". Setting that to "Enabled" seems to have solved the issue for me.
My motherboard is the ASUS Crosshair X670E Hero and the BIOS version is 2506.
I hope that helps.
polymeros77
•4mo ago
I hope that helps.
