- 10 Jan 2009
- Now live in Scotland !
The build
Asus Rog Hyperion GR701 case
Asus Rog maximus Hero Z690
Asus Rog Ryujin ll Cooler
Asus Rog Thor 850w P2
Asus Rog Hurculx
2x 3x 120mm pack Lian Li Infi fans (mirrored versions) 6 in total for push pull
1x 140mm for rear same fan
Lian Li RGB power and GPU cables.
Lian li fan cable splitters for mobo.
I9 13900k
64Gb (4x16) Teamgroup 6000mhz RGB
2x 2TB Samsung 990 pro in raid0
2x 2TB m.2 x3 game storage (already owned)
4tb Samsung 2.5mm SSD (already owned)
Zotac RTX 4080 amp extreme.
Asus fans that’s come with cooler will go in the front of the case.
I would like to know if I would run into any issues with the Asus Aura and Lian li Connect softwares ?
I would like to run all fans and RGB within one software but don’t think it’s possible.
Would I be better off plugging the lian li fans into RGB header onto Asus mobo ?
All items in basket here in overclockers accept PSU 850w Thor p2 as not listed in stock.
I might paint the case. Not built a Pc since 2015/16 (that build is on here) Project Osiris.
Asus Rog Hurculx
I9 13900k
