Asus ROG Strix B760-F Memory Channel Issue - Help Needed Please
16 Feb 2025
UK
Hi all,
New member and like lots here I have an issue. I have built up a new PC however I cant get the PC to recognize more than one memory stick.
PC specs are:
ASUS ROG Strix B760-F Motherboard
Intel I7-14700KF CPU
Arctic Freezer 3 420 AIO
Corsair Vengeance 32GB DDR5 5600Mhz (2 x 16GB) memory kit (CMH32GX5M2B5600C36K)
Asus GEFORCE RTX 4060TI 8GB Graphics Card
Samsung 1TB SSD
So far I have:
Made sure board is at the latest BIOS - Its is on the latest
Checked both CPU and memory are listed on the ASUS compatability list - They are
Tried all combinations of memory position. The PC will only boot with one slot (B1) filled. Nothing else.
Loaded up Windows 11 whilst on one channel to see if somehow that made a difference and allowed two - It hasnt
Checked LGA1700 socket for bent or damaged pins - There arent any
Tried multiple combinations of pressure on the screws for the AIO with no success.
RMA'd and tried a new motherboard - No success
RMA'd and tried a new memory set - No success
Now down to CPU. Any other thoughts as they are expensive items and very difficult to test.
Aye, it sounds like the CPU is the only one left and it needs to go back.
You could try picking up a cheap i3-12100F (or similar) and see what happens with that, but obviously that's more expense and hassle.
Yep, done just that. Purchased an i3-12100F from a handy large next day retailer thats currently in its Prime! Will see if that works and if so then I know its the CPU.
