ASUS ROG Strix RTX 3080 White V2 RGB Issues
10 Sep 2013
I have just received the above last week, and the RGB situation is horrendous.
I have iCue installed for my Cooler and Fans, it found the GPU but every time the PC reboots it loses the settings.
So I went to install the ASUS Crate and that worked for a few hours, now I have no lights at all on the left half of the GPU
I did a fresh install of Win10 to no avail
I have looked online for answers again to no avail
Anyone have any ideas please?
I had a somewhat similar experience, albeit the TUF isn't quite as 1337_>9000_RBG as the Strix.
iirc remove armoury crate and install ASUS AURA. This programme should allow you to properly control the RGB. Moreover it somehow improves how icue interfaces with ASUS hardware, so you should be able to control the Strix with icue.
If none of that works, look into the 'open RGB' software, it's getting quite good now.
