ASUS ROG Swift OLED PG32UCDP
19 Nov 2007
Leicester, UK
Anyone got any idea when or even if these will be back in stock at OCUK?
Is there a problem or summat
You can get the UCDM from a fair few places, but just dont want a glossy
Have you contacted ocuk?
I still keep going back and forth between ucdp/ucdm/msi dp2.1 option. Everytime I think I know what to do I flip the other way. I like the woled but the qdoleds are cheaper - is the woled worth £300 more? I also kind of want dp 2.1
If I could get a dp 2.1 woled that would be ideal.
I suppose that would be a good idea...lol Was kinda hoping that one of the staff would see this and chime in.
For you.... another option if you NEED DP 2.1 is the AORUS FO32U2P £1200
I deffo need a matte screen. The glossy even though fractionally better PQ under the right lighting condions, reflections for me are far to distracting.
So have no choice to wait for the UCDP as nobody else does a matte with the same specs as the UCDP
The F032U2P doesn't have enough watts on the kvm to use for my CAD laptop otherwise yep this would be an option. I don't need DP 2.1 tbh its more of a want and i dont think DLDSR is compatable with DSC
There is the LG Woled but it has a fan and no KVM it seems like the asus is better
