- 17 Oct 2024
- Newcastle
ASUS ROG ZEPHYRUS G15 GA503QS NVIDIA RTX 3080 32GB 15.6 QHD 165Hz Ryzen R9-5900HS Gaming Laptop
After using it as a workhorse for the past 3 years, it seems that I'm now running into some major issues; to the point I can no longer use it at all.
Was getting m.2 issues to the point where it wouldn't even post. Wiped the drive and reinstalled Windows, and now I can't install any programs because it's blue screening with "Memory Management".
MyAsus diagnostic tool says it's a RAM issue.
I've taken the RAM out that you actually can take out and the issue still persisted, leading me to believe it's the onboard RAM. I've sent it into ASUS RMA, but I've heard awful things about them and I'm dreading hearing the cost of repair that they're going to quote me for a new board (if that's what they end up diagnosing).
Is there any alternatives out there that will attempt to fix the board instead of replacing entirely? Cheers.
