- 5 Nov 2005
Hi all,
Really hoping for some miracle help on here….I recently got a Asus RT-AX86U to replace my old RT-N66U, the new router seems to have amazing rang, I can’t get Wi-Fi half way down the road in all directions but I do have one extremely frustrating issue I cant seem to resolve and starting to run out of ideas so really hoping for some help!!
The issue is that I have a Chromecast connected to my amp in the corner of the living room which is the same room as the router is in and I use this solely to stream music from Google music\YouTube music, so I sit down in the evening and cast to it and have the music on in the background, I have been doing this for years with no issue but with the new router the music just keeps cutting out every once in a while for 1 or 2 seconds, it can do this cutting out everyone 10\20 seconds or slightly larger gaps.
The things I have tried so far are below –
Any idea’s help would be great!!??!! Thanks all
- I tried 3 different Chromecasts, 1st, 2nd and 3rd gen, all do the same
- I tried splitting the network up so I have 2.4ghz and 5ghz SSID’s, putting the Chromecasts on ether seems to have same issue.
- I tried removing all other Wi-Fi devices from room in case of interference and does not seem to help
- I have checked and its does not seem to be a particular Wi-Fi channel that causes issue.
- Changing loads of settings on router, I checked my old routers advanced Wi-Fi settings and matched them on new router with no luck.
- Android TV with new router the TV would not auto connect to network at first until I connected it via WPS with 5ghz and now stays connected
- Bandwidth on everything seems fine, the android TV and google mini work fine that are right next to Chromecast location, I could be gaming and playing a 4k film without issue but the Chromecast will keep cutting out.
- Rebooting the router or changing settings and the router doing a soft reset while saving seem to fix it for a while, after changing settings or a reboot the issue wont come back for many hours.
- The router is on the latest firmware.
