- 19 Oct 2011
I am using this system that I have just recently built
Motherboard: Asus Sabertooth P67 B3 Rev
CPU: Core i5 2500K
CPU Cooler: Corsair Hydro H60
Memory: Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz
PSU: Coolermaster Silent Pro 1000W
Graphics: MSI GeForce GTX 580 OC Twin FrozR II 1536MB
Sound Card: Asus Xonar D2X 7.1
HDD: OCZ Agility 3 120Gig
Case: Coolermaster HAF 912
The motherboard comes with a utility to monitor the motherboards various temperature sensors and the CPU and it is these sesnors that my questions revolve around. After a few hours of intense gaming (Battlefield 3 maxed out or Skyrim) the CPU hits 32 degrees which I believe is great but the GPU hits around 88 degree which I think is causing some of the motherboard sensors to have a fit. The sensors around the USB 3 chipset, SATA 3 and the PCI-E ports all go above 70 degrees to around 72 causing them to shade in red. The system still runs perfectly stably however I dont like these readings. Are they too high for the motherboard and is it going to break running like this?
Cany anyone please tell me what I can do to help this situtaion OR if it isnt an issue shall I disbale the temp warning message and just forget about it if its safe for the motherboard?
Thanks
CPU: Core i5 2500K
Thanks
