asus settings help
27 Jan 2005
Letchworth Herts uk
Hi All I am running the Asus RT-N56U Router with Infinity ,but want to know what the best settings are ? ie channel bandwidth 20Mhz or 40 Mhz ? & Authentication method ? plus 2.4Ghz or 5Ghz ? :confused:
I use 20/40 & WPA2 AES
To get the most from infinity I find the 5ghz network the best, so use that for all devices that you can. Some, like my kindle and printer can only use 2.4 ghz so that's where having dual band really helps.
Also, put a nice strong password in, let's say 10 characters
