- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
The Asus Silent Knight II Cooler is a great looking cooler with great cooling properties.
The design will not cause any issues for high memory heatsinks or limited space mATX cases.
Our price is way better than any other reseller. We only have a limited number of units, get this cooler before it runs out.
Asus Silent Knight II CPU Cooler (Socket AM2/AM3/1155/1156) @ £12.98 inc VAT
The SKII is made of 100% copper materials and the six copper heat pipes ensure excellent heat dissipation for maximum cooling performance. It's PWM function automatically adjusts rotation speed according to CPU temperature and delivers a quiet cooling at a mere 25dBA. The fan positioned inside the frame and VRM shield guides cool air to critical components around the CPU for stable operation
- 6 innovatively designed heat pipes increases heat transit capacity
- Inner PWM fan delivers quiet cooling at a mere 25 dBA
- Universal clip design for easier installation
- Materials: copper fins, heatpipes, base
- Fan Spec: 800-2300RPM, 12V, 0.26A
- Fan Dim: 25x92x92mm
- Heatsink & Fan Dim: 140x110x115mm
- Weight: 610 grams
Only £12.98 inc VAT.
ORDER NOW
- Weight: 610 grams
ORDER NOW
