Asus Silent Square Pro or Scythe Ninja Plus Rev.B
29 Jan 2007
Hi,
I'm going to be building/swapping hardware around in a few PC's in the next week or so and want to replace the stock Intel cooler I have on my X6800 when I move it to a new BadAxe 2 mobo. I also need a cooler for an E6700 that will be going in the old BadAxe in my current system. I do not plan to do any over clocking of these systems but would like a good, fairly silent air cooler in both.
I was looking at either the Asus Silent Square Pro or Scythe Ninja Plus Rev.B or any other suggestions. I did have the Thermalright Ultra-120 Extreme but was concerned about the reports of the base that sits on the CPU not being flat. Both of these systems are in Akasa Mirage cases.
Can anyone recommend decent coolers for both, I will also be looking for a cooler for a QX6850 which is going on a P5K3 Deluxe board at the end of the month. This will be in an Antec P182.
I have a Scythe Ninja Rev. B cooler on my P180 which is pretty much the same as the P182, and it's able to run passively (kinda) due to the 2 case fans which are quite close to it at the top and back of the case, so kinda adds to the silencing of the case.
