Hey,
Going to be using the Coolermaster HAF X v2, the Asus Sabertooth X79 motherboard and the H100 in push/pull. The fans are going to be maxed out:
HAF X
Top: x2 200mm Cooler Master Mega-Flow
Rear: x1 140mm Stock
Side: x1 200mm Stock
Front: x1 230mm Stock
Vga Funnel: x1 120mm - Cougar Vortex CF-V12HP
Vga Bracket: x1 80mm - Noctua NF-R8-PWM (maybe)
H100 (CPU_FAN header driven)
Top & Bottom of Rad: x4 120mm - Cougar Vortex CF-V12HP (H100 pump driven)
Maybe some: Antec spot coolers.
Wondering if I should go with a fan control module or use the ASUS headers as there are some impressive reviews on their software (Fan Xpert 2). What do you think?
HAF X
