Asus Striker II settings
11 Oct 2007
London, UK
I am having issues with getting my board to run at 1600Mhz (on the RAM/CPU). No matter what way (auto oc/manual etc) I dont seem to be able to get my RAM to run at 1600mhz stably. Well, tbh, i am having issues even when its at very slack timing (1066) so i guess its not the RAM. The PC will just "freeze" occasionally, this can be on desk top or in game. Tamps are fine, not relly going above 50-55 on NB and SB( load), sitting at 35-42 (idle or load, load is after 2.5 hours of prime blend) on CPU depending on which program i believe, 45-50 on GPU's (idle) Case temp is around 19-21 depending on sunnyness :). With the setting below (i cant remember all of them and im not at home) I got prime to run for 2.5 hours without a single hitch.
Running the same as below but with my RAM at 1600 might work but it owuldnt mem test and i hadnt got round to priming after changing a lot of the settings. I would ideally like to get it working at 1600 linked and synced, or higher. When i Ran it at 1600, tried up to 1.325 Vcore, a nothc extra on all the other volts i have set manually, and tried SB up to 1.6, core 3 would get an error in Prime Small FFT's and sometimes cause a crash. I'm mainly wondering what sort of volts i should be selecting for the ones I've left on auto. Core 3 does run around 8 degrees colder than the other cores, I have reseated my waterblock and paste etc and it made 0 difference. The corsair kit im using states [email protected] for 1600mhz.
The last board/CPU i clocked properly was a P4 socket 478 so didnt have a lot of these options, as such io dont know what i should/shouldnt be doing with them :(
Can anyone offer any advice on the below settings?
Case: TJ-07, custom, dual rad in top, triple rad in bottom, all fans replaced etc.
Mobo: Asus Striker II Extreme
PSU ( Power Supply Unit ) = Tagan 1300W
CPU = Q9450
RAM = Corsair DDR3 1600Mhz Cas 9 (2x2GB stick atm, awaiting RMA on the other pair)
HDD = 1TB Samsung F1 (another 4 in Raid5)
VGA1 = GTX 295
VGA2 = GTX 295 (in a week or so)
SPU ( Sound Card ) = Asus D2 Xonar
NorthBridge Cooling = Stock, no fan or WC
SouthBridge Cooling = ^^
CPU Cooling = 120.2 Rad + D-tek fuzion
RAM Cooling = Dominator Fan
nFORCE Chipset Drivers Version = latest, 15.36 or something
ForceWare/GeForce Drivers Version = 182.06 (got them 4 days ago, so maybe a different number)
Sound Card Drivers Version = Latest.
BIOS version = latest
BIOS Settings
Extreme Tweaker
CPU Level Up = Auto
Memory Level Up = Auto
AI Overclock Tuner = Manual
CPU Multiplier = 8
FSB - Memory Clock Mode = Linked
FSB - Memory Ratio = Sync
FSB (QDR) MHz = 1333
MEM (DDR) MHz = 1333
LDT Frequency = 5x (standard)
PCIE Bus Slot 1 & 2 MHz = 100
PCIE Bus Slot 3 MHz = 100
SPP<->MCP Ref Clock, MHz = cant remember - standard
SLI-Ready Memory = Disabled
Memory Timing Setting
P1 = Enabled - (doesnt seem to make any difference putting these on auto)
P2 = Enabled
tCL ( CAS Latency ) = 9
tRCD = 9
tRP = 9
tRAS = 24
Command Per Clock (CMD) = 2t
tRRD = cant remember
tRC = cant remember
tWR = cant remember
tWTR = cant remember
tFAW = cant remember
tRD = cant remember
tRTP = cant remember
tRFC = cant remember
tREF = cant remember
Over Voltage
CPU Voltage = 1.225
Loadline Calibration = Disabled (i get CPUinit 70% of the time if i set this to enabled)
CPU PLL Voltage = Auto
CPU VTT Voltage = Auto
Memory Voltage = 1.76 (overvolts to 1.8)
NB Core Voltage = 1.48 (over volts to 1.5)
SB Core Voltage = Auto
CPU GTL REF0 Ratio = Auto
CPU GTL REF1 Ratio = Auto
CPU GTL REF2 Ratio = Auto
CPU GTL REF3 Ratio = Auto
NB GTL REF Ratio = Auto
DDR3 CHA1 Ref Volt = Auto
DDR3 CHB1 Ref Volt = Auto
DDR3 CHA2 Ref Volt = Auto
DDR3 CHB2 Ref Volt = Auto
CPU Configuration
CPU Internal Thermal Control = Disabled
Limit CPUID MaxVal = Disabled
Enhanced C1 (C1E) = Disabled
Execute Disable Bit = Enabled
Virtualization Technology = Disabled
Enhanced Intel SpeedStep(tm) Tech. = Disabled
CPU Core 2 = Enabled
CPU Core 3 = Enabled
CPU Core 4 = Enabled
Spread Spectrum Control
CPU Spread Spectrum = Disabled
PCIE Spread Spectrum = Disabled
MCP PCIE Spread Spectrum = Disabled
SATA Spread Spectrum = Disabled
LDT Spread Spectrum = Disabled
I think thats what im on. I updated it like 2 weeks ago. Site is currently down so i cant check which version it was i downloaded.
just remembered, my q9450 is an early one (bought very near release) so w/e stepping that is. Sorry I would have definate info but im not at home and i wont be for a while
Try setting command rate to 1T? I know AndyOCUK has the same RAM as me, but my RAM would freeze in vista with 2T command rate, but was perfectly fine with 1T.
Also, disable P1 + P2 (set to auto). This does make a difference if you benched your RAM using everest. P1 + P1 gives better read + write scores.
I have this board, and could not for the life of me get even 1600 fsb with a 6x multiplier on this board. But, I have been informed by a number of people on various forums that my Q6600 L870A... batch is the thing holding me back. Anything above around 1400 fsb will result in random bsods and restarts.
As I said, try 1T.
Also, try running memtest to see if it's a RAM issue, and disable legacy USB in BIOS before running memtest.
@Andy, I tried your settings, and even with an 6x multi my pc would always reboot after 30-50 minutes. It's crazy. it'll pass intel burn and memtest, but random bluescreens and restarts.
That's a totally different rig!! lol. I have given up at 3ghz with this now.
Just a quick question if anybody will read it.....
It is stable @ 1333 fsb with 9x multi. But is unstable at 1600 even with a 6x multi. Is that mobo or cpu fault? Even with 1.5v NB and 1.6v SB (remebering to keep temps in check) it still bsod and restarted after 30-50 minutes of normal use.
The cpu needs 1.45vcore to stay stable at 3ghz though, which is a hell of a lot compared to other Q6600s. Bad chip?
ok, cheers for the advice, ill check thins out later today when i can be bothered to get out of bed...stupid beer lol
