Had the card since about Nov 22nd, worked fine then around 15th December it just started randomly making one fan out of the three (the closest to the back of the card with the ports on) run at 100% and it sounds like a goddam helicopter taking off.
Its definitely not the "zero DB mode" of the fans before anyone suggests that, the fans all turn on together for that when the temp gets up on the card and this is totally random
I can turn my pc on and leave it idle with nothing open except monitoring apps, card is sat at about 32c with 0% load and the one fan just turns on at 100%.
Every monitoring app ive tried also shows the GPU fan at 0% RPM when its happening too.
I've tried:
Uninstalling GPU tweak 2
Installing MSI afterburner.
Removing all other fan monitoring apps to check for conflicts.
Used DDU to totally remove all nvidia drivers, reinstalled the latest one.
It did occur to me last night maybe the problem was coming from me updating to latest drivers sometime in december so i installed the november drivers i had put on when i first got the card.
If anyones got any ideas that would be a massive help, trying not to go down the RMA route so i havent got to go without my pc gaming for a few weeks.
I've tried:
