Hi all,
I just received my so long awaited Strix. It's the non OC model basic one.
It has Samsung Memory as shown below with my current manual OC settings.
Ran many times Time Spy & Fire Strike benchmarks with no issues.
My temps never go over 55-58 degrees in the benchmarks at 60% fan speed.
That is the max core OC I can give since the benchmarks freeze over +215
Probably due to the cheap 112% Power Limit it has. Upping the voltage also didn't really amount to any noticeable differences either.
Now, I did upped the memory to +1000 and it ran fine, but how do I know it is still safe with +1000 ?
Would the VRAM chips heat a lot more but would not show in my general temps or if my general temps are still at 60 degrees it means that nothing is hotter then that on the whole card ?
Would this OC shorten by lot the lifespan of the card ?
Is this OC any good compared to others ?
I need good guidance for that if someone has the experience. What's you'r impressions ?
Thanks
Thanks
