Asus Strix 4090 + EK vector2 ABP Waterblock + X570 Godlike MSI motherboard Clearance Issue ?
26 Jan 2004
Scotland
I didnt even think of this when i bought the ek 4090 abp waterblock set....
can anyone tell me, cause i know its going to be tight and i didnt want to start before knowing so i can plan a fix as i might need to saw off 10mm of the bottom io vrm godlike sheild from the motherboard to make the waterblock abp fit... as the clearance will be tight as i require 15mm of space above the top most pci express slot....
has anyone installed this block on the godlike x570 motherboard ?? as i need help before i start
thanks.
