Hello all,
So on cyber Monday I decided to buy an Asus strix vega 64 card from OC UK to replace my gtx 970. Generally speaking I'm happy with the performance but I am having one issue I can't get to the bottom of so I hope someone here can help me sort it as I really hope it isn't a faulty card and I have to send it back.
The problem is intermittently if I step away from my pc, when I come back and turn my monitor back on and press a key or move the mouse to turn on the display it does not turn on and I get a no signal message on the monitor. The only way to get the monitor back on is to hit the reset button on the pc and restart it. This does not happen when I am using the pc or when the card is under load during a game etc, it only seems to be when it is idle so I'm confident the 750w psu is good..also I didn't have this problem with the 970 and the same monitor also using the display port.
The mb I have is a Asus crosshair V running latest Windows 10
Things I have tried so far
Used ddu and rolled back driver to previous version 18.9.3
New display port cable
Removed and reseated card
Changed pcie cables from psu
Unplugged other monitor and vr headset
Disabled fast start and sleep
Any help would be appreciated.
Cheers
Cheers
