- 15 Feb 2025
- turkey
Asus tuf gaming b550 plus is not starting
Yesterday it was working without any problem. It had nvme hard drive on it. Windows was on it. I removed this to give someone, then i would install ubuntu to my other ssd but after removing nvme, it started not to work. I could not boot it.
When i connect to psu, only lights come but it does not start when i press buttons or use screwdrivers.
I disconnected everything. eXcept cpu because hard to remove it. I can also try in last case if i cant find any solution.
I downloaded TUF-GAMING-B550-PLUS-ASUS-3611 bios driver which is latest from website of asus and flashed it also. IT did not help. maybe i was not doing correctly because i created that usb stick on ubuntu machine by formatting to fat and patsed the folder. But usb port green light disconnec ted after minutes while both usb and that light was on so i think it worked and i think not about it.
psu:
digitalpromo.co.uk
ram: ballistix ram double
there is cpu amd and 2 rams . ALso rams cant be taken without removing cpu.
amd ryzen 7 5800 8 core cpu.
I am posting some items to show how motherboard is and how i tried to boot and my bios update files.
Should it be about power pins broken or psu or cpu or bios, how can i be sure? I checked lots of posts but i could not succeed with how they succeeded
I am waiting any helps . Thank you.
https://imgur.com/a/0pCuh0v
psu:
GamePower Gp-650 PC Power Supply
GameMax GP-650 White Edition 650W 80 Plus Bronze Fully Wired Power Supply
650W GameMax GP-650 WHITE Edition, 80 PLUS Bronze, Non-Modular Fully Wired, Single Rail, 1x140mm Fan, ATX PSU Manufacturers Code: GP-650-WHT3x Molex Connectors5x SATA Connectors2x PCIe Connectors (6+2-Pin)4+4-Pin CPU Power ConnectorATX Form Factor
