- 27 Jan 2022
- UK
Gskill F5-6000J3038F16G SK Hynix 2x16GB and Asus TUF Gaming B650-Plus Wifi motherboard, I've flashed to the latest BIOS for the long overdue logo security fix.
Before I could only get EXPO timings to work at 5600Mhz now the proper EXPO at 6000 seems to be working so far (30-38-38-96-134 1.35V).
Should this be all good then? I take it the RAM is in fact great and it was a motherboard issue before? Should I do some memtest?
OT but, I forgot about the other random hoops to jump through, everything was default again and the BIOS doesn't showing when connected to display port, only HDMI, then video was jerky and Hitman was 2 fps, remembered this from a year ago, disabled iGPU in BIOS, games and video are now fixed! sigh
Before the BIOS saves changes it gives a review of the pending changes - now this is slightly better as I can make a note of that and using this at least know the name of the settings, then I just have to find them.
I find the following equally confusing/boring/annoying: instead of 'DRAM voltage' it's called 'DRAM VDD Voltage / DRAM VDDQ voltage / PMIC Voltages sync all PMICS / Memory VDD voltage' and I have no idea what they mean and also gl finding them in the BIOS. also EXPO I or II? I closed my eyes and picked one
/annual bios update rant over cya next year
