Asus tuf LED software
20 Apr 2015
I seem to have acquired a 3070 tuf oc thingy, to put in my PC. As the PC has a Z-97 board without RGB headerness, is there any software to control the colour changing logo, or are snips the best way to control the RGB?
d
TUF 3090 here. Armoury crate has never picked up my card to let me change it nor has ICUE ever given me the option to change it. Ended up leaving it on rainbow puke.
you have to have both softwares installed, ie armoury crate and icue latest updates, I use icue to control the leds on my Asus tuf 3080oc and it works fine, you don't need both running at the same time, I have icue running both my corsair keyboard and gfx card, they show up and no problems! but saying that only got it working recently on the latest icue update 4 something, it's a shame that the various manufacturers can't get together and come up with something universal that "just works" ! I did try an open source led software that controls all types but it's still in the development stage and a bit hit and miss.:p
I only have Armoury Crate installed which is able to turn off the RGB lighting. I did in the past also have ICUE installed for the LS100 strips for monitor lighting, but since changing monitor I have uninstalled.
I know you do and I did but it still has never worked for me. Fully aware HOW to do it all and set it up but its still never worked.
I know you do and I did but it still has never worked for me. Fully aware HOW to do it all and set it up but its still never worked.[/Q
that's strange, mine works fine? just goes to show what a **** up the rgb software world is at the min!:)
rgb software is the bloody pits! one min its working the next its not - hope one day there will be a one stop solution for all rgb i have used an open source one before but even that was a bit hit or miss!
