Asus TUF RTX 3080Ti Waterblock?
17 Jan 2007
Is there one at a sensible price? I was looking at the Phanteks ones but not sure which one would fit? There seems to be a TUF 3080/3090 one and a 3090Ti one, but not a specific 3080Ti one.
EKWB one seems to be EOL.
I don't really want RGB as it will be in an Ncase M1, but no biggie if it does.
And I have an evga 3080ti
Pretty sure it said fits
3080,3080ti, 3090 on mine
So it's possible the phanteks one would fit
Though obviously you have to be certain
When it comes to gpu blocks
Again, not the same, but I've got the alphacool block on my 3080ti and the temps are great. I would trust they're not idiots and even if the memory temps are slightly higher than other blocks, it's not like they're worse than the stock cooler which in turn is nowhere near the tjmax of the chips.
